2009 lr2 hse
Old Jan 4, 2017 | 05:50 AM
bosalls5's Avatar
Default 2009 lr2 hse
Climate Control issues: Cabin is over heating, defrost stays on while my feet are cold? Switching from Auto to Economy has no effect on interior temperature. Temperature dial will not modulate temperature. Heated seats are working fine. Directing air flow (defrost, dash or feet) has no effect. Replace climate control module?? Temperature sensor??
Thanks Bob
Old Jan 4, 2017 | 07:50 AM
bosalls5's Avatar
Another possible suspect is the Motor Lever Heater Flap (LR048448 or LR003173) modulates a door in the mixing plenum that is a possible bad actor.............anyway to test the motor?
Thanks Bob
Old Jan 6, 2017 | 04:21 PM
bosalls5's Avatar
I was able access the area (very tight) for the Motor Lever Flap (passenger side / behind the glove compartment) and the electrical connection is small, almost a micro connection. Trying to use a meter to test for voltage and continuity would be difficult. I have noticed that the control panel is easier to find / purchase used or new which makes me wonder if the control panel has a higher failure rate than the motor. Looking for some feedback from any tech's out there.
Thanks Bob
bkuberek
LR2
Oct 5, 2016 05:54 PM
FAST5
LR2
Jun 27, 2014 05:05 AM
Bastian Kuberek
Apr 18, 2014 04:30 PM
windermereLR2
Jul 18, 2013 05:39 AM
JakeHalliday
Feb 23, 2011 10:54 PM
