2011 LR2 - Door Issue
Every post pertaining to this particular subject matter, varies a little, allow me to post the specifics of my issue.
2011 Freelander 2 / LR2 / L359 / 3.2L DOHC MPI Petrol I6
Just recently, I can no longer unlock, or open, from neither inside nor outside, the Drivers side, REAR door, (the door directly behind the Drivers door).
As seen in the pictures, the physical lock, (A), can not be moved, it is frozen in locked position, (in).
And if I use either dash buttons, (B, C), you can hear that there is still the same mechanical sound as always inside that door, as though you should be seeing it open and lock, but it just isn't doing anything.
The window works on that door, and all other doors on the vehicle still work perfectly, just not that one.
Without being able to open the door at all, one wonders how any repair could even be implemented.
