2011 LR2 tboned
Hi, Advice needed.
Car was in accident, t-boned. Air bag curtain went off, no one hurt.
Right rear passenger door took brunt of impact.
Rover has about 130K miles, and ran great.
From what I can see no damage to undercarriage, or wheel well.
Need to replace door, or pull out dent, paint, and replace trim
Adjuster said pillar needs to be replaced, I don't see it.
I am in Arizona and my choices are based on
Claims adj. valuation of: $7902.00.
Insurance said it is a total: pay out of $8283.00,
Ins. Estimated repair is Repair $11,000K which exceeds 70-80% value, which brings the value to $6899.00, if I chose to keep, salvage and repair.
If I find someone to repair for 6899.00 or less then Insurance will pay for repairs and I keep title.
What would you do?
What would you do?
I did that for an acura TSX which I really loved. That worked out because it was cosmetic, no frame or mechanical damage. But probably wouldn't do it again.
1. PITA (in CA) to get the salvage title, have to smog and do an extra safety inspection and a bunch of paperwork. New plates.
2. Salvage title means even lower resale value, so if you get in another accident you're probably not getting your money back out of the car.
3. Many reputable shops and body shops won't touch a salvage title. I had to drive down to the border to get another parking lot dent fixed.
If you're going to do it be absolutely certain the frame isn't bent. Would also suck if the doors don't close right, or rattle on the road.
Hi, Advice needed.
What would you do?
What would you do?
I say all of this because I don't know your financial situation. If you can afford to take the money and roll it into a newer car, then that's definitely the way to go. But if you're on a shoestring budget barely making ends meet, then there are often reasonable options if you know where to look.
Hi, Advice needed.
What would you do?
What would you do?
The LR2 is a unibody vehicle... and its been t-boned!! Get over it and move on already! As @flydb5 suggests, $8283 is a nice bit of coin towards the next vehicle... that I hope for your sake is "newer" as opposed to "older"
Cheers.
Cheers.
disgruntledexlandroverowner.com
LR2
Apr 29, 2016 11:33 AM
