Hi all could someone help me figure out how to disconnect blue circled pressure hose connect? I need to replace this line from pump to steering rack. I tried disconnect tools but nothing worked.
I do not understand what you are trying to do. Those are pressure fittings. They are not designed to be undone after they are crimped. The hose/pipe usually comes as a complete assembly. The crimp marks ought to make that clear.
Hi thanks for the reply but these are two different hoses got connected here and could be disconnected as far I know. I just want to know if someone has previously did it. I got new part but that hose is only upto that rubber part you see.
And i did contact my local land rover, they are saying its a disconnect able pressure fitting. And rubber says EATON STC after googling I see these are connector. So I just dont know how to disconnect and wants to know if someone has actually achieved it. Looks like same type but this one is 90
