2013 lr2
Old Mar 17, 2022 | 02:43 PM
ourx15's Avatar
Thanks for all the info. Much appreciated. It’s going into the mech. this weekend. Changing oils and what ever else he finds/recommends.
Old Mar 21, 2022 | 10:02 AM
guy's Avatar
guy
You have 100,000 miles on the ecoboost, 4 cylinder turbo engine. It is a direct injection engine and prone to gunking up.
As Fly2b suggests. Change ALL fluids. Not just the oil.
And have the state of the valves checked. You may need a flush prior to the oil change.
That is
Power steering
Coolant
Power Transfer Unit
Front differential
Rear differential
Rear 4 wheel drive clutch (Haldex unit)
Brake fluid
And all filters.
That particular engine and platform calls for synthetic fluids. (I know, I have one)
Are the brakes done? Alignment done? Canada is a big place, where exactly are you? The reason I ask is I wonder if the 4 wheel drive system has been extensively used.
If it gets cold in your neck of the woods, an inline heater is golden. (used to be called a block heater but now they install on the coolant line as opposed to heating up the oil)
There are many precise electric components in this vehicle. If the battery is not 100%, change it. It should register 12.8 volts after sitting over night.
Preventative maintenance will take you a long way. If you let things go, it gets very expensive, very quickly.
I use all terrain, all seasons in the summer. Only winter tires in the winter. The winter tires are on smaller rims.
I do agree with your daughter (and my daughter) that the driving position, manueverability and road handling are excellent for an suv platform.
Welcome to the club!
Craig J Gagnon
Oct 14, 2020 07:54 PM
clark grizwald
LR2
May 24, 2013 04:58 AM
roverreitzel7
LR2
Feb 27, 2013 09:51 AM
scarrittjd
LR2
Dec 5, 2007 05:42 PM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
