2013 LR2 will not start after getting gas
Old Jan 18, 2022 | 02:16 AM
sadiebroome-coombs@hotmail.com's Avatar
Default 2013 LR2 will not start after getting gas
Hello. I have been dealing with this issue for about 6 months. Now every time I get gas my car will not start. I took it to get fixed and he changed the battery. It starts fine until I fill up. At the pump I can play with it and hold the start button and give it gas and eventually it starts if I throw it in drive when I hear it start to turn over. It is so frustrating. Any ideas what this could be?
Old Jan 18, 2022 | 06:28 AM
guy's Avatar
guy
I’m afraid at this point I have more questions than answers.
1. are you “topping off”, possibly triggering an emissions sensor?
2. is the fuel tank cap making the air tight seal? also triggers a sensor.
3. “giving it gas” shouldn’t be necessary during the start cycle. Are you flooding it?
4. Is it worse in winter?
5. gasoline or diesel? premium fuel?
6. water in the tank? when’s the last time you put some gas line antifreeze through it?
And most importantly, what codes are you throwing and is the engine light on?
I’m afraid I just don’t have enough info to go on. And it isn’t helpful not to know what part of the world your in nor what specific vehicle you have.
Old Jan 18, 2022 | 07:47 AM
Default Follow up questions
Thank you so much for looking into my issue further.
I rarely ever let my tank get below 1/4 empty but this happens at all levels of fullness
2. is the fuel tank cap making the air tight seal? also triggers a sensor?
actually.. the last couple time the cap has been so sealed that I can hardly turn it .. it is so stuck!
I have found today that the only way to get it started after fueling is if I push in the break with left foot while using my right foot to rev the engine on the gas pedal while also holding the start button.
this seems to have gotten worse in the cold weather yes but it was happening in the summer months
premium gas
I have never done this but it recently is asking for antifreeze .. may mean something
no engine lights are being shown
we are in Maryland USA
Old Jan 18, 2022 | 09:18 AM
flybd5's Avatar
It sound like the fuel system purge valve or emissions pump are not working right.
Old Jan 18, 2022 | 10:57 AM
guy's Avatar
guy
Agreed @flybd5 ... but no codes??
And ONLY during refueling??
Blocked charcoal canister? I'd expect a fault light on the emissions for that.
Something to ponder over beer and crabcakes... sadly, I'm not in Maryland.
Old Jan 18, 2022 | 11:00 AM
flybd5's Avatar
I get the exact same symptoms, but I know I need to change my purge valve (bought it, too lazy and too cold to get to it right now). I have changed the canister already and did the smoke test and yes, I have a code, but if it happens only after refueling I can't think of any other reason. What I do is floor the accelerator when starting and as soon as it starts I let off the pedal.
Old Jan 18, 2022 | 12:40 PM
ThorInc's Avatar
First, JIC, don't put coolant/antifreeze into the gas tank! The reservoir is in the engine compartment and is the clear tank on the left, fill to high level line.
Read this but it's long, it could be the Crank Position Sensor?
https://landroverforums.com/forum/lr...se-help-78491/
Another good thread:
https://www.freel2.com/forum/topic29...t=hot+soak+key
and another:
https://www.freel2.com/forum/topic29...light=hot+soak
Old Jan 18, 2022 | 12:55 PM
flybd5's Avatar
Whoa! The car is asking for antifreeze and you think it has to do with the gasoline tank???!!! That's the ENGINE COOLANT warning, it means your reservoir of coolant in the engine compartment is low! You run the risk of overheating and permanently damaging your engine if you don't deal with that immediately!
ggushee
LR2
Apr 27, 2020 08:00 AM
LR2driver
LR2
Jan 12, 2015 06:07 PM
rscisme
LR2
Jun 27, 2014 08:37 PM
david426
Jun 16, 2013 07:58 PM
Drnknmnky13
Dec 22, 2008 01:37 PM
