Alarm /Remote starters
Old Dec 8, 2015 | 02:51 AM
akmega's Avatar
Default Alarm /Remote starters
I have purchased 2008 LR2 SE and the same night I'm having random Alarm goin off. I don't see any messages on the screen and I double checked each door trunk and hood shut. Would I be able to disabled the alarm if locked the door manually or leave the doors unlocked until I go back to my dealer? I was told that many LR2 don't come with Remote starters and it's not recommended due to electrical problems. Any suggestions?
Old Dec 8, 2015 | 12:53 PM
LR2driver's Avatar
If you leave the doors unlocked, that should keep your alarm off until you get it repaired.
The problem might be your Hood Alarm Switch. You can perform a google search to find a video showing how to replace it.
Please post back and let us know the final resolution.
Old Dec 8, 2015 | 02:06 PM
akmega's Avatar
What if I lock it Manually is the alarm still ON or off ? Thanks
Old Dec 8, 2015 | 09:48 PM
LR2driver's Avatar
My guess is that the alarm goes on when the locks are on, but I don't know for sure. A simple test would be to roll down your drivers window so it is fully open, close the door and lock it manually with the key. Allow it to sit a few minutes. Then reach in through the open window and open the door from the inside. If the alarm is on, it will probably sound.
Old Dec 9, 2015 | 01:47 AM
akmega's Avatar
Ok so after work I tried both test with windows down and locking it Manually and no alarm sound after opening . I tested with locking with fob and opening it, the alarm sounded. I did get message after for the first time that Bonnet open and then it disappeared.
Old Dec 9, 2015 | 02:33 AM
LR2driver's Avatar
Good test. If you feel ambitious and want to try replacing the bonnet/hood switch yourself, this video might help:
How To Replace The Hood Latch On An LR3, LR2 or Range Rover Sport
Old Dec 22, 2015 | 11:47 PM
akmega's Avatar
Finally got my Hood latch switch replaced and no problems yet, was able to get the part from Landrover $39.99 Can. Thanks again
Bakari75
May 8, 2013 07:44 PM
cavdiver2
Aug 6, 2012 12:01 PM
Suede
Oct 4, 2009 01:19 AM
puffoff
Jan 16, 2009 12:29 AM
mlshelton
May 5, 2008 12:20 AM
