Another frickin' bug hunt.
Does anyone know which fuse goes with the front side marker lights on an LR2? The small bulbs inside the headlight assembly, above the high beam bulb? I can't get them to light up with or without load resistors, or even with the original lamps, and I can't locate which fuse controls power to that socket. I know the ones on the fenders are powered by the same circuit as the turn signal.
F11 in the CJB is about engine management. In the pax compartment fuse box its reverse lights and interior mirror dip. In the rear fuse box there's only an FA11 for trailer power. ??
Did you know the rear fuse box has a fuse for "caravan fridge"? Funky!
The standard 13 pin trailer plug has a pin for "fridge". Probably the work of some drunken German gynecologist, same one who invented the sport of "luge."
