Coolant Hose Removal
Old Jan 20, 2019 | 11:16 AM
Inkstaind1's Avatar
7th Gear
Default Coolant Hose Removal
We developed a leak, a hole, in the lower elbow of our lower coolant hose. Seems like an easy fix but we cannot get to the clamp that holds the airbox tube/pipe to release it so we can move it out of our way to get to the coolant hose connections.
Anyone ever completed this task?
Old Jan 20, 2019 | 11:23 AM
Inkstaind1's Avatar
7th Gear
It’s a 2008, and here’s the hose.
Old Jan 21, 2019 | 11:03 AM
p_gill's Avatar
Is this the hose that's leaking?
I replaced mine when I remove the intake manifold to replace the Thermostat
Freel2.com - View topic - 3.2 Thermostat replacement
the part number is LR005564
If this isn't the correct hose then do you know the part number?
As for the clamp, pliers exist for removing this type of clamp but I use Channel lock pliers
Amazon Amazon
Amazon Amazon
Good Luck
Paul
Old Jan 22, 2019 | 09:18 AM
Inkstaind1's Avatar
7th Gear
Thanks Paul, yes that’s it! I thought we would just have to remove the Plenum. Easier said than done LOL.
Old Jan 22, 2019 | 10:25 AM
p_gill's Avatar
No problem
I recommend that you replace the Thermostat, heat exchanger coolant hose and the leaking hose at the same time
Parts needed
LR006071 - Thermostat
LR001491 - Screw for Thermostat (Qty 4)
LR001442 - Coolant Hose for heat exchanger
LR000491 - Bolt for Heat exchanger hose
LR001505 - O-Ring for heat exchanger hose
LR005564 - Coolant Hose (because I'm paranoid)
Remember: the tip of the heat exchanger hose will be broken off and you need to remove it and the old O-ring from the block.
Good Luck
Paul
Old Jan 26, 2019 | 06:49 PM
Martimouse55's Avatar
6th Gear
Default Upper coolant hose
i’ve searched until I’m blue in the face. How the heck do i remove the upper radiator hose on a 2008 LR2? It has some quick connector that i can get one hand on but can’t figure out what to do with it.
Old Jan 27, 2019 | 12:23 PM
Inkstaind1's Avatar
7th Gear
Originally Posted by p_gill
No problem
Parts needed
Good Luck
Paul
Thanks Paul for your help with this, much appreciated. This is my sons car and he just decided to take it to the shop. They fixed it in 3 hours, and did say it was tough to get to. For $150. In this case, we should have done that right away considering he spent $200 on rental car that week lol.
Old Jan 28, 2019 | 10:07 AM
p_gill's Avatar
Inkstaind1,
That is a good result
It has been my experience that it is almost always better to know how to do the job even if you get someone else to do it.
It helps two ways
1- to prevent an unethical technician from over charging you
2- so that you understand why it cost $150 and not $5 and you are glad to pay it
I completely agree with your analysis $150 now is better then $200 every week
With that in mind here are two links that you may want to look into
The first is maintenance and repair items for older LR2's (Based on my research of what fails)
Freel2.com - View topic - Common items for high mileage 3.2
The second is my chronicle of Maintenance and Repair for my Volvo S80 that I bought with 125,000 miles (note: the Volvo uses the same engine and transmission as Land Rover, If I bought an 10 years old LR2 I would do the same work, plus a bit more due to the all wheel drive system)
https://www.matthewsvolvosite.com/fo...p?f=31&t=87687
Good Luck
Paul
zuke
Sep 25, 2018 07:42 PM
lrnoob
Apr 22, 2018 02:21 PM
bballjames
Jul 30, 2012 10:43 AM
01disco2
Sep 10, 2010 02:31 PM
werldcup
Mar 14, 2007 05:05 PM
