Extremely loud squeal coming from the starter area.
Old Jun 23, 2019 | 12:48 PM
Marty Birchmeier's Avatar
Default Extremely loud squeal coming from the starter area.
I get a loud constant high pitch squeal that sound like it's coming from the starter/ transfer case area. It does not change with engine rpms, just stays constant. It starts a few seconds after the engine starts and can be heard winding down a few seconds after turning it off. I dont want to just start tearing stuff apart. Any thoughts?
Old Jun 24, 2019 | 03:20 PM
p_gill's Avatar
Take a look at this link
https://www.freel2.com/forum/topic31456.html
Old Jun 27, 2019 | 05:45 PM
Jade Dockery's Avatar
Default Same
Mine started too last week. Super annoying. Couldn’t pin point the sound. But mine finally threw some codes so after I changed the tps and throttle body and I started her up it stopped. Maybe a pin hole in a hose or vacuum leak. Wish I could help more.
Old Jul 26, 2019 | 04:42 PM
Nico's Avatar
Wink
I had the same problem last week, just when the car is hot. When cold there was no noise. On all regular cars there is a PVC valve, on the LR, there is none, instead they have a CRANKCASE OIL SEPARATOR which cost about $150.00 USD. Google LR023777 to see a picture of the part, find it under the hood and blow some smoke on the gasket while running. The scriching noise is air escaping a worn out seal.
Good luck
Old Jul 26, 2019 | 11:42 PM
Default Fixed
It is the oil trap deflector/PCV piece. There is a YouTube video that shows exactly this issue. If you remove the oil cap or dip stick while it’s running and whistling and it goes away then that’s your key to diagnosing it.
Old Jan 10, 2022 | 09:09 PM
Lynn LR2's Avatar
Default Land Rover LR2 whining or squeal noise
It’s your transfer crankcase PVC valve cover. I’ve had to replace mine twice in two years on my 2009 LR2. When the engine is idle you’ll hear the sound, pull the oil dip stick and the sound disappears that will confirm.
Old Jan 11, 2022 | 08:45 AM
merlinj79's Avatar
I've replaced the PCV twice within 2-3 years, still makes a mild honking noise when cold although that goes away after warmup. Very occasionally pops the dipstick out.
HBW1020
Aug 6, 2019 07:12 PM
disco2disco
Jun 1, 2015 12:19 PM
AAD2
May 18, 2011 10:10 AM
apcollin
Dec 3, 2008 11:58 AM
mackshawnd
Apr 24, 2007 01:58 PM
