fuel pressure dtcs
Hi,
I am working on a 2008 land rover lr2 and we have fault codes for fuel pressure and temperature sensor. We have replaced the sensor but we still have the fault. When we check the voltage with Autologic scanner, at the sensor it is reading 80 volts! and the pressure is reading 700+ kpa.... has anyone had this problem?
It cant be 80 volts so I am thinking it is a software fault...?
The car runs ok but when you start it, it starts and stalls, and then starts and runs ok.
Any help would be appreciated.
there was a bulletin for this issue i beleive its instrument pack and engine control module reflash. By the way im in the process of buying the autologic scanner how is it working for you so far any faults? does it do everything they claim it does?
JumPeR04
Apr 7, 2011 09:52 PM
