Help with electrical
Old Jun 24, 2021 | 10:16 AM
Stevelongislandleisure's Avatar
Angry Help with electrical
hi, i have a 2011 LR2. i recently got into a minor accident on the front end driver side. Broken Headlight and bumper. After this happened, the brake lights went out for some reason. So, i had all fuses tested and they all work. Now, test the brake lamp switch and that is getting no power. Had the car scanned and codes coming up:
c0023-13 stop lamp control- circuit and b1115-13 high mounted stop lamp control- open circuit.
i noticed that the front turn signal bulb was broken and wire was crimped a little bit.
i changed the bulb and that works.
please help with the rear taillight situation. Any idea what it could be?
Brake light control module?
Any wiring diagrams available here?
please help!
Old Jun 24, 2021 | 12:08 PM
flybd5's Avatar
For both codes the repair manual states "Refer to electrical circuit diagrams and check for open circuit." Looks like you have to deep dive to find where the wires got cut or disconnected.
Old Jun 24, 2021 | 02:05 PM
thank you. Any chance you have a wiring diagram?
Old Jun 24, 2021 | 03:17 PM
ThorInc's Avatar
Default C
I would also check the grounds...........if you search this site you should find a "grounds" diagram as well as a download link for the electrical & service manual....you will have to find one for your year class.
Old Jun 24, 2021 | 05:34 PM
flybd5's Avatar
Google for the Freelander 2 service and maintenance manual. It's downloadable from the Internet and the wiring diagram is the same as the LR2.
angrylobster
Jan 4, 2024 12:40 PM
dhaselhorst
Feb 8, 2015 05:34 PM
Dabigkahuna
Sep 21, 2014 12:45 PM
ROSMOND2K2
Nov 12, 2008 07:59 PM
chrisusvi
Feb 12, 2007 11:32 AM
