Passenger side slightly cold drivers side outside temp
Old Jun 26, 2021 | 09:22 AM
Mo1313's Avatar
3rd Gear
Exclamation Passenger side slightly cold drivers side outside temp
Can someone please assist myself with this dilemma before I get the wrong part/quote from a local AC guy.
I recently did a tune up on my 2009 LR2 HSE everything was working fine. I had ice cold AC and now I am getting kind of cold air from the passenger side and outside temp. for the driver side.
Old Jun 26, 2021 | 09:59 AM
merlinj79's Avatar
Check the settings on the AC pabel.
Is it operating in dual mode, ie are the driver and pax temp settings very different? My wife does that all the time.
Old Jun 26, 2021 | 10:07 AM
Mo1313's Avatar
3rd Gear
Yes, of course brought both sides to 60 degrees and going from cold to hot hot to cold a couple of times as well.
Old Jun 27, 2021 | 09:26 AM
ThorInc's Avatar
Sounds like a stuck "blend" damper.......look at the "related topics" just below this post or thread.
Old Jun 27, 2021 | 09:34 AM
merlinj79's Avatar
This car is like microsoft windows, first step in troubleshooting anything electric is the reboot.
- Disconnect the battery cables.
- Wait ten minutes.
- Touch cable ends together
- Reconnect cables to battery
- Wait ten
- Insert key in slot
- Wait ten*
- Turn the car on without starting engine (foot off brake, hold start button in)
- Wait ten*
- Start engine
*optional but might help
If that doesn't help, then it might an actuator the operates a splitter door or maybe a temp sensor on one side. That seems most likely...
https://www.freel2.com/forum/topic15...r+conditioning
Might also possibly be low refrigerant, not sure how the airflow splits inside but if the streams flow over different parts of the heat exchanger.
Also does it work better if the car is moving? That could be the radiator fan or fan controller. In either of those cases if it's warmed up and sits idling you should see the coolant temp needle move above it's normal position... DON'T operate it above normal at all, that can damage several things and if you get the warning message it's too late.
But my guess would be a splitter door actuator. On dual control units it's good to exercise those occasionally by setting the two sides to opposite extremes, and the reversing them to the other extremes... otherwise if you never use the dual mode, the actuator might never actually move which typically is not good for mechanical parts.
Old Jun 27, 2021 | 12:00 PM
flybd5's Avatar
Are you sure that you didn't touch anything other than what is needed for a tune-up? I would find that a little difficult to believe, as nothing that you do during a tuneup will have anything to do with the climate control system. The dual zone system is a bit complex and there are several things that could fail, from the stepper motors in the blower assembly to the cabin temperature sensors in the cabin. There is a single fuse for the blower motor assembly, 40A, and no separate ones for the stepper motors. The simplest thing I can think of trying is removing the climate control panel and making sure all the connectors are seated properly.
Old Jun 27, 2021 | 08:40 PM
Mo1313's Avatar
3rd Gear
Thank you Everyone,
I took it to my local AC guy gave it a quick charge and the AC is working like new again, but I was told that there was no Freon in the system so maybe a leak did the dye test we shall see what happens.
Regards,
Mo
Old Jun 28, 2021 | 01:10 AM
flybd5's Avatar
Thank you Everyone,
Regards,
Mo
The refrigerant storage is supposed to be sealed. If you lost it, there is a leak, or someone emptied the system.
Old Jun 28, 2021 | 09:02 AM
merlinj79's Avatar
Yeah the leak probably didn't fix itself... unless it was maybe one of flush/fill connectors and it got re-seated when the shop re-filled it.
NigelT
Defender
Apr 22, 2021 02:49 PM
ALScott
Oct 18, 2018 07:41 AM
LRtoo
LR2
Jun 26, 2016 05:06 PM
a_wick_2010
LR2
Jun 11, 2015 02:58 AM
ShaggySE7
Jul 17, 2013 02:08 PM
