Hi, LR2 won’t start. Starter fuse blown, starter replaceo
Old Oct 14, 2022 | 10:17 PM
sagsat's Avatar
From: I don’t really know at this point of my life. Republic, State, ohh yeah a colony of the US
Originally Posted by merlinj79
Reset the computers again:
Disconnect both battery cables (neg first)
Wait ten minutes
Touch battery cable ends together
Wait ten
Connect battery (pos first)
Wait ten
Insert key fob (don't turn on)
Wait ten
Turn car systems on, but not the motor (with foot off brake, press and hold start button for a few seconds)
Wait ten
Start engine, drive around a bit
Will try again tomorrow, thanks.
Old Oct 14, 2022 | 10:18 PM
sagsat's Avatar
Originally Posted by flybd5
I am not 100% sure, but I think you can remove a cover under rear cargo area liner to get to the top of the fuel pump. You should be able to see the pump, the breather hose and the electrical connector. You should also be able to hear the pump running when you turn on the ignition.
Also, the EVAP system has two components, the filter box in the rear and the emissions purge valve near the throttle body. The fuel system on the LR2 does not have a return line. The ECM tells the pump module how much juice to send to the pump to give the engine what it requires. If you open the gas cap slowly and hear a rush of air, it could be that one or both of these are clogged and not working. It is a VERY long shot, but that might keep the fuel from getting to the engine. The purge valve near the throttle body is cheap and easy to change (I have an extra one if you need it). The filter, not so much so.
Also, check the engine breather system. It must be free from restrictions and correctly installed, or the engine may not start.
If the pump module in the rear works and sends power to the pump but you are still not getting fuel to the injector rail, you're gonna have to hunker down and drop the fuel tank. If the filter is clean, you will have to change change the pump. Unfortunately, that is a difficult task.
Thanks , another task to try.I appreciate everything you guys doing to help me.
Old Oct 15, 2022 | 08:00 AM
flybd5's Avatar
I just realized that if you open the gas cap, hear air rushing in, leave the cap off and the engine starts, you will know the problem is one of the evap system components, likely the purge valve.
Old Oct 17, 2022 | 08:34 AM
sagsat's Avatar
Hi, the cover of the fuel pump is under the rear passenger seat It’s easy get to it , now it time to start working on it. Weekend was for the family, now week days , it’s work days.Thanks for all support everyone is giving! Will be posting updates on the exorcism of the rover.
Old Oct 17, 2022 | 08:36 AM
sagsat's Avatar
Yeah if the big red cable is 60K then the big fuse must be blown. IIRC it's under the black plastic cover where it attaches to the battery terminal.
So far so good. I’m removing intake , and battery cover today.
Old Oct 17, 2022 | 08:37 AM
sagsat's Avatar
Thanks for everyone for the support. I really appreciate that , if we we’re close i’ll buy everyone a round of 🍺!
Old Oct 17, 2022 | 08:38 AM
flybd5's Avatar
If you're going to exorcise it, make reservations, that one they got out of that little girl in The Exorcist is still taking up the entire basement at the Carmelite Sisters convent in Cleveland. They roll him out on Halloween to scare the neighborhood kids.
Old Oct 17, 2022 | 09:12 AM
ThorInc's Avatar
Yes, but if the pump actually has to be replaced, you will have to drain the tank and drop it. If on the chance you are able to defy "natural laws and various gravity", , bravo!
Old Oct 17, 2022 | 04:14 PM
sagsat's Avatar
Hi, i found out that while removing the air filter someone used some kind of tape to fix the plastic hose coming from the intake , and i can see more tape on the plastic intake below near the bottom of the engine. Seems like a new plastic hose is needed from the intake and the air filter. Just a new finding! yayyy. I’m so happy , i’m going to have to remove the whole air intake to get down there, i try from below but was almost impossible. A picture !!!!
I wonder who was the last mechanical that worked with this?
Old Oct 19, 2022 | 06:50 AM
sagsat's Avatar
