Holy cow.
GPS jammers are also highly illegal and can land you in a federal jail. They are also easy to detect and track down. If the car has a tracker and the thief is scared of it being found with him, guess what, it did its job. I know you are covering the obvious, but most car thieves do not go to such lengths. You know that as well as I do.
The small jammers in question only affect a small area, ie they'd be enough to keep a car from using GPS to locate itself but not enough to disrupt navigation in a significant area (start messing with air navigation, and that would get you some attention for sure).
But GPS jamming might not even be enough, a car with a cell-based on board system can locate itself via cell towers, although less precisely than GPS.
Thieves are using sophisticated technology, because that's the only way to actually steal modern cars in most cases. Jammers are not a stretch...
https://www.ksat.com/news/2019/03/12...teal-vehicles/
https://www.forbes.com/uk/advisor/ca...ess-car-crime/
Once they use tech to steal the car, they probably have to do something to keep it from phoning home with it's location.
Get caught using one, even a "personal" one, anywhere near an airport and find out what happens after they lock you up. Ever heard of something called a "GPS approach"?
That's wrong. EVERY AIRCRAFT in the sky (commercial or private) using required ADS-B is doing just that, by monitoring and reporting of GPS signal quality, and there are tools onlline to make the locations of the jamming signals by triangulation.
There's nobody actively monitoring for or searching for jammers...
Those small jammers would not affect an aircraft, too far from the ground. Small personal jammers only jam GPS devices in near proximity to your person, so it would prevent your iphone or possibly the nav system in your car from knowing your location.
Unlike in the case of ground based radio navaids, a GPS jammer is not physically between the aircraft receiver and the satellites.
I bought this: https://www.amazon.com/dp/B09QYG17S8...roduct_details
$45. Put in any SIM card you want, I use a cheap $5 a month SpeedTalk card and only use SMS. The unit has a very rich feature set including several low power options, including do nothing until you sense motion. It comes with wiring and a relay you can use to remotely cut either ignition or fuel pump.
I generated a phantom disposable CC number on PayPal. I also get cash back. I pay once a year and do not allow them to store any financial info.
I see. I would probably get a $60 disposable Visa Gift Card and just swap it out with a new one every year. Similar to your solution.
That will work just as well, but I am considering switching to a data-only sim card on my Google Fi account.
