How to install air intake for lR2?
Old Jul 28, 2012 | 12:13 PM
mstiho's Avatar
4th Gear
Default How to install air intake for lR2?
we bought air intake for lR2. the dealership doesn't know and doesn't have part and skills, they have recommeded someone but they are not sure about their quality. so we bought it via e-bay.
to take off the original filter is easy but to mount a new one is a big deal:
it stays loose and there is big open hole that belongs to original system that doesn't fit to anything in a new intake system. Is there any picure or step by step installation process published somewhere? how to mount it so it won't be loose and what hose or interface is going to connect to the hole that stays open?
that is what we purchased:
2008 - 2011 Land Rover LR2 / HSE 3.2L I6 BBP AIR INTAKE SYSTEM W AIR FILTER
Old Jul 28, 2012 | 12:48 PM
IMHO the change to this type of filter won't return the "performance gains" you may have desired. Plus the "oiled rag" style filter allows dirty oil mist to foul the mass air flow (MAF) sensor in many situations. How many mpgs were you hoping to pick up?
If it "did" add 26 HP and 10% mpg increase the web site claims, we would all have them by now. And yes, I'm a sucker and have one, but will likely put the oem stuff back (D1).
Old Aug 13, 2012 | 04:47 PM
Rovin4life's Avatar
the loose stuff usually rattles around and damages wiring. plus its does nothing what soever.
Old Aug 22, 2012 | 10:30 PM
angelis745's Avatar
If you change to an aftermarket air filter, use one of the new dry filters. there is no need to oil it and since its a synthetic cloth you can wash it, dry it , and put it back on. Also if you use anftermarket air filter, you should install a less restrictive exhaust system.
bcolins
Mar 8, 2015 12:07 PM
svntsvn
Feb 25, 2015 10:43 PM
richief556
Sep 17, 2009 09:23 AM
okarpf
Mar 29, 2008 08:06 PM
u2fan1967
LR2
Feb 2, 2008 09:29 PM
