Intake manifold gasket replacement
Old Jan 6, 2021 | 08:34 AM
Hamza89's Avatar
Default Intake manifold gasket replacement
Hi guys ,
Do you recommend to use gasket sealant when replacing the intake manifold gaskets ?
thanks
Old Jan 6, 2021 | 08:52 AM
flybd5's Avatar
Why in the wide, wide world of sports would you do that if they are only $15 or so for a set on eBay from Victor Reinz? No, bad idea.
Old Jan 6, 2021 | 09:21 AM
Hamza89's Avatar
I already purchased the gaskets , but I saw some people applying sealant on the new gaskets as well , just to make sure the surface is sealed , so I am asking whether should I apply the sealant on my new gaskets or not .
Thank you
Old Jan 6, 2021 | 09:23 AM
flybd5's Avatar
That's a different question. The service manual does not recommend doing that.
Old Jan 6, 2021 | 09:34 AM
Hamza89's Avatar
yeah the manual did not mention any sealant , however some people recommend to use the sealant on the older cars since the surface condition will not be so great .
but I think I am going to follow the manual and just use the new gaskets without any sealant , I will follow the torque specs as well .
Thank you very much for your continuous support really appreciated
Old Jan 6, 2021 | 09:40 AM
flybd5's Avatar
The intake is the one place where I would never put any sealant, because if any of it comes loose it's going to play havoc and create a lot of grief for me to clean it out. If the surface condition is a bit rough, put a rag into each of the openings to protect the intake and use something like a steel wool pad to smooth it out, or very light sandpaper. Carefully wipe everything down before reassembling. Most of the time, however, this is not necessary. If it is noticeably rough then you probably have significant corrosion inside as well and need a new manifold. You can find them used at car-parts.com in any one of the thousands of chop shops in the US.
Old Jan 6, 2021 | 09:44 AM
Hamza89's Avatar
Yeah that is exactly why I did not want to apply sealant , for this car you might need to remove the manifold many times for access , it will be a pain in the neck to clean it every time , so I won't use it .
thank you again man 👍
Old Jan 6, 2021 | 09:47 AM
flybd5's Avatar
You're welcome. Let us know how it goes.
Old Jan 9, 2021 | 07:26 AM
Hamza89's Avatar
job was successful , no sealant used just the new gaskets torqued to 16nm as per the service manual , I also cleaned the throttle body coz it was missed up , the results were amazing , thanks a lot 👍
Old Jan 9, 2021 | 07:36 AM
flybd5's Avatar
Outstanding
Abigail Galloway
Aug 20, 2020 07:31 PM
me 2
May 12, 2012 09:32 PM
teeboli
Mar 16, 2011 09:11 AM
jasonabarrett
Jun 26, 2010 09:08 AM
old gold
Oct 21, 2008 10:26 PM
