Leakage under the oil pan
Old Oct 6, 2025 | 07:50 PM
merlinj79's Avatar
Not that hard, the VVT is oil powered, but electrically controlled.
For a given oil pressure you need X voltage to open the control solenoid far enough to achieve the desired timing.
Install a pressure sensor, then map control voltage vs. measured oil pressure. Probably need a third axis to cover a range of temperatures.
I'm pretty sure my Autel will provide estimated engine oil pressure?
Similar to how they map fuel delivery when tuning on a dyno.
But agree, a sensor and gauge would be nice.
Old Oct 6, 2025 | 07:51 PM
flybd5's Avatar
Too many failure points. I prefer the switch.
Brandon318
May 8, 2025 03:10 PM
cvhyatt
Jan 14, 2022 07:55 PM
Brandon318
Jul 2, 2021 12:16 PM
04disco2va
Dec 13, 2020 04:16 PM
Rover_Hokie
Sep 27, 2012 04:42 PM
