LiquiMoly MoS2 Anti-Friction Engine Treatment
Old Jul 23, 2020 | 10:14 AM
  #21
merlinj79's Avatar
What oil are you running with the LM?
Old Jul 23, 2020 | 10:28 AM
  #22
flybd5's Avatar
Mobil 1 5w-30 normal (not high mileage).
Old Jul 23, 2020 | 07:45 PM
  #23
LR2driver's Avatar
Originally Posted by flybd5
Mobil 1 50w30 normal (not high mileage).
That's full synthetic, right? Did you notice any difference when you switched from a blend to full synth?
Old Jul 23, 2020 | 07:46 PM
  #24
flybd5's Avatar
I've never used a blend, always full synthetic.
Old Jul 23, 2020 | 07:50 PM
  #25
LR2driver's Avatar
I guess that makes sense as you are in a climate that has cold winters where full synth is better.
Old Jul 23, 2020 | 08:04 PM
  #26
flybd5's Avatar
I am not sure LR calls for other oil grades in different climates, though. Let me check...
No, the manual calls for 0W30 A5/B5 in -all- climates. But since none of the retailers or oil change places like Jiffy Lube have it, I would have to order from Amazon if I wanted to use it, I think. But hey, I just saw that LiquiMoly makes a 0W30 full synthetic A5/B5, and guess what, they also say:
"This lubricant was developed primarily for use in various Volvo models with these specifications in various vehicle types"
A clue, Sherlock. I had no clue. Hmm. I think I'm going to have a chat with that LiquiMoly sales manager.
Old Aug 8, 2020 | 02:00 PM
  #27
flybd5's Avatar
1. I was wrong about the oil grade. The manual calls for 5W-30 in North America.
2. After two weeks my city mileage appears to have stabilized around 18.4 mpg. Highway still a little over 23. Compared to stock 15/22, not bad.
Old Aug 10, 2020 | 08:58 PM
  #28
LR2driver's Avatar
15/22 is not typical. Stock is the 18/23+ you are getting now and matches what I've always gotten, as well as other LR2 loaner vehicles the dealer would let me borrow when I used to go there for service.
Old Aug 10, 2020 | 09:29 PM
  #29
flybd5's Avatar
I can only compare with what the manual says and my own experience. Mine has 163k, and when I got it I was getting the 15/22 more or less.
Old Nov 15, 2020 | 01:47 AM
  #30
LR2driver's Avatar
Originally Posted by ThorInc
I've used in in a previous vehicle without issue for about 3-4 years and I am using it currently in the 2008 LR2 since I bought it pre-owned just under two years ago, issue free. I have also used the Liqui Moly Ceratec during one oil change interval in that time period. Reason why I used it in the LR is because the previous vehicle, a V6, it did make the engine run significantly quieter.
I read that Ceratec is supposed to be a more advanced formula (also costs 3X more than Moly MoS2). But Ceratec is not advised for use in vehicles with a "wet clutch". Does the LR2 have a wet clutch?
