Low engine performance message and no power at all until the car warms up
Old Feb 7, 2023 | 02:07 PM
p_gill's Avatar
Asheligh,
There are several things that could be happening.
The Built in diagnostics are really good so you should have some codes (in the future get the codes from the Mechanic even if they reset them and the code doesn't return)
1. The transmission control module could have a problem and it might start you in 2nd or 3rd gear (use the manual mode to verify that you are in first gear when the problem is happening)
2. The Fuel Pressure sending unit could be faulty - if the pressure isn't what the ECU thinks it is then the power could be very low and then if the sensor works when it is warm then the power will return (this should set a code or at least have very high fuel trims and misfires) If the sensor is frozen and you have some water in your fuel then strange things might happen. How cold is it when you have the problem.
3. The Intake Variable Valve Timing Solenoid could be faulty - it is possible that the ECU limits power but it should set a code
4. Intake Variable Valve Lift Solenoid there are two - if you don't switch to the high lift state then you will have about 30 Horsepower instead of 230 Horsepower this will absolutely cause the type of problem that you are having (but once again you should have a code)
Good luck
Paul
PS with LAND ROVER you need to be exact. You wrote "I get the message saying Poor engine performance" but I think the actual message is "REDUCED ENGINE PERFORMANCE". I realize that they sound about the same but we need precise information to help you out.
10milestereo
Freelander
May 23, 2022 07:13 AM
Justas
Freelander
Dec 29, 2019 08:39 AM
Leeshort1
Jan 3, 2014 01:03 AM
grr
Freelander
Oct 10, 2007 03:52 AM
richard49
Sep 15, 2007 07:53 AM
