LR2 Starting Issue
Old Oct 22, 2019 | 03:59 PM
bige67's Avatar
Default LR2 Starting Issue
Hi all,
this issue may have already been addressed so apologies if that is the case.
Yesterday I backed my 2010 LR2 up where a small sandpile slightly pushed up onto the bottom of it. Then I proceeded to shut it off and load it up with a heavy load of stones. After that when I put the keyfob into the socket, it would not start. The lights would sometimes light up when trying and you could hear a click when you pushed the ignition button, but there was no sounds from the starter at all. I tried jump starting it, I tried jump starting with a battery cart. Then I had it trailered home and put it in the garage on trickle charge overnight. The load of stones were offloaded after I got home. I went out this morning and again tried to start it. The reaction was the exact same. I took a multi meter and measured the battery charge. It was sufficient. I tested the starter related fuses and found them good. I swapped the A/C and starter relays since they were of the same specifications. I am just about stumped here and could really use some help. Is there an inertia switch that I can reset on this model and does anyone know where? Do I need to do some kind of security reset? Thank you in advance for your help.
Old Mar 7, 2020 | 06:42 AM
Discodave76's Avatar
Sounds like starter solenoid is stuck, a tap with a hammer can dislodge it and get it started, but you can also buy repair kits with all parts cheaply on eBay
Old May 23, 2023 | 11:10 AM
Nic_E's Avatar
I know this was a long time ago, but what ended up being the issue? I just got a 2010 LR2 and its doing the exact same thing.
Old May 29, 2023 | 06:15 AM
mvan231's Avatar
we had the same issue on ours and had to replace the starter. Ours was killing the battery after sitting for a few days though but then eventually the starter locked up entirely and wouldn't even make a sound
Old May 29, 2023 | 10:22 AM
merlinj79's Avatar
1. If the battery is more than four years old, replace it. This car has no tolerance for large voltage drops on starting... running a tired battery is asking for all kinds of trouble.
2. If the battery is newer, charge it and the test it (use a DIY tester take or it to FLAPS). Replace if it's not in good shape.
3. If that doesn't solve the problem, replace starter.
Old May 29, 2023 | 03:45 PM
curb-optional's Avatar
My LR2 had a starter problem too. In my case the engine started, but not immediately - kinda iffy. so the dealer swapped out a computer chip and said the circuit board that controlled the engine starting was going or damaged, and best bet was new one. that worked and not have any other issue it. that "not starting so easy" sensation was probably a week or two, maybe 3 weeks - but obviously glad I checked it out. didn't happen every time either. sometimes fine, sometimes a bit slow.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
MechanicRob
LR2
Dec 27, 2022 06:16 PM
Dawave
LR2
Jun 25, 2019 02:09 PM
LR2driver
LR2
Jan 12, 2015 06:07 PM
jclark1012
LR2
Feb 23, 2013 08:27 AM
