O2 Sensors
Old Jun 3, 2012 | 09:12 PM
bboretsky's Avatar
5th Gear
Default O2 Sensors
Need to figure out which is left and right on the O2 sensors. O2 Bank 2 is dead and I need to figure out which one is which.
Thanks...
Old Jun 3, 2012 | 09:48 PM
Your engine is "sideways", so the end with the belt that drives everything would be the nose of the engine. Bank 1 would be toward bumper. Bank 2 would be toward firewall. All four O2s and several other sensors get power from same point, so may not be a single loose wire. See attached from RAVE.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 3, 2012 | 10:08 PM
bboretsky's Avatar
5th Gear
I see both Bank 1 and bank 2. I just need to figure out which is sensor 1 and sensor 2 in bank 2...I only want to fix the correct one.
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
Corsair33
Sep 18, 2006 10:15 PM
riebs
Aug 21, 2006 11:48 AM
JRdisco1
Aug 9, 2005 03:33 PM
