Oil leak
Old Dec 12, 2021 | 07:57 PM
Swiftreptar's Avatar
3rd Gear
Default Oil leak
Hello everyone I have a 2012 LR2 and I noticed that the low oil pressure light was on. So I checked the levels and it was extremely low. Does anyone know of general oil leaks that LR2s have? I added about 3 qts and the levels were back to being good. I've only had to replace both the differentials in the car. It has about 104,000 miles on it, oil changed regularly. I've not noticed any oil leak spots but did check the oil filler cap and it smelled a little burnt and looked blackish on the underside when I was checking the level today and filling it up.
Old Dec 12, 2021 | 10:42 PM
flybd5's Avatar
Mine burns about a quart every 2-3 thousand miles or so. You have stay on top of it otherwise your oil level will drop too low and you risk catastrophic damage to the engine. Have you been checking it regularly? If not, start doing so. If you have noticed no oil spots under the truck then I suggest you run the car and check the oil level every day to see if it is dropping while the vehicle is being driven.
Old Dec 13, 2021 | 09:38 AM
merlinj79's Avatar
Yeah, they burn a little at higher mileage.
I switched to mobile 1 high mileage oil around 120K, that seems to help. It has additives which help the seals. I'm guessing valve stem guide seals are the issue (maybe with some out the rings too).
Also might be a good idea to remove the splashguard under the engine and see if it's soaking wet with oil... that could hide an oil leak. The brake vacuum pump seal is known to leak oil, and that's an easy DIY fix (they sell a kit). You can see that from the top of the engine if it's leaking.
Old Dec 13, 2021 | 09:45 AM
flybd5's Avatar
I bought a case of that and still have to add a quart every 3,000 miles. Someday soon I will have to think about tightening up things on the engine.
Old Dec 13, 2021 | 12:58 PM
merlinj79's Avatar
Wonder if the valve seals can replaced without removing the head?
Old Dec 13, 2021 | 12:59 PM
flybd5's Avatar
Now THAT is wishful thinking.
Old Dec 13, 2021 | 01:15 PM
ThorInc's Avatar
Interestingly, my 2008 i6 only starts consuming oil after about 2-3K miles after a fresh oil change. Now I am using Amsoil XL with Liquimoly CeraTec during the winter months. I wonder if it may have something to do with resetting the oil service schedule counter?
Old Dec 13, 2021 | 01:16 PM
flybd5's Avatar
Huh? What would the counter have to do with oil consumption?
Sarge103
Feb 25, 2013 05:40 AM
ESPN
May 3, 2012 07:42 PM
buick215
Jan 29, 2011 01:08 PM
humroot
Jul 3, 2010 10:29 PM
kfox77
Apr 25, 2009 01:29 PM
