Opening the rear hatch without removing the key from the ignition?
greetings All.
To be clear, there is no dock for the fob in the 2013. There is a sensor under the steering column but we have never had a need to place the fob against it.
Yes, of course there is a latch button on the fob for the rear tailgate.
But how often is the fob in my hand once I’m seated in the vehicle… never. The fob remains in my pocket. There should be a button on the dash or on the door panel…. clearly an oversight.
Jeepers… I may have just justified a need fir the new defender…. following some depreciation, of course
Cheers!
Cheers!
Guy,
Enter your VIN into the decoder
https://www.vindecoderz.com/
My 2008 has
Door Locking Mode - Central Door Locking inc Tailgate/Door [076DC]
Does your 2013 have 076DC?
More info
https://www.freel2.com/forum/topic32610-15.html
Take care
Paul
My 2008 has
More info
Take care
Paul
That might be my next one, after the LR2 goes off to college in a few years.
Any idea who makes the drivetrain? A big OEM, or english garden gnomes?
The point of what I was saying is that if the FOB doesn't have to be in a slot, that might explain why they though it OK to remove the feature to unlock the rear hatch from the dash.
I have not heard good things about the new Defender. In fact, all I have heard is bad reviews about the truck.
"Transmission Order Code
NA
Transmission Description
Automatic w/OD
Number of Transmission Speeds
First Gear Ratio (:1)
5.50
Second Gear Ratio (:1)
3.52
Third Gear Ratio (:1)
2.20
Fourth Gear Ratio (:1)
1.72
Fifth Gear Ratio (:1)
1.32
Sixth Gear Ratio (:1)
1.00
Seventh Gear Ratio (:1)
0.82
Eighth Gear Ratio (:1)
0.64
Reverse Ratio (:1)
3.99
Final Drive Axle Ratio (:1)
NA
Transfer Case Model
Electronic
Transfer Case Gear Ratio, high (:1)
NA
Transfer Case Gear Ratio, low (:1)
NA
Clutch Size
NA"
I'll definitely give it a couple years for the dust to settle, not going to fly the A model of anything haha.
Basic IT rule: Never install version x.0 of anything.
DoubleAFL
Sep 14, 2019 10:57 AM
HollandandHolland120
Oct 18, 2007 06:49 PM
