Reduced Engine Perf., etc.
I have a 2008 LR2 that has never given me serious problems but today it starts popping up with DSC fault, reduced engine performance, transmission fault, etc. It shut down and I can't drive it. Can anyone tell me what the problem is? I have a local mechanic here that can look at it because the dealership is about an hour away.
reduced engine perf
My 2008 LR2 had exactly the same problems and registered the same error messages. It was the battery, I had it jumped, tried to get it to charge, but it wouldn't hold the charge. If you are still under warranty (48k I believe) your dealer should replace it for free. Judging from what you listed, I'd say that's your issue too.
Good luck,
Tracy
Good luck,
Tracy
Thanks so much! I did change out the battery but my battery light remains on. My husband said I may just need to run the vehicle a while to charge up the battery. I'm actively looking for an alternator right now. Can anybody give input? My battery light came on just a couple of minutes after I put the new battery in.
Athana
11-02-2017 10:25 AM
achapman
06-25-2013 03:40 PM
06Range
05-08-2013 09:01 PM
2008, battery, change, dead, engine, fault, land, light, lr2, perfomance, performance, reduced, replacement, rover, start, status, transmission
