Rough engine idle CK engine light on
Old Nov 4, 2022 | 05:38 PM
Viking1's Avatar
Default Rough engine idle CK engine light on
2008 LR2 75,000 miles started it this morning and immediately running rough and CK engine light came on it’s been a very reliable LR
most obvious?
new exhaust and cat last year
original spark plugs
Its time for me to purchase a diagnostic code reader for this trk and my 2005 V8 LR3 which is mint 100,000 miles
snyway can someone please rec an reasonable priced analyzer? As well as point me in the right direction on the LR 2 rough idle and CK engine light? Thanks guys
Old Nov 4, 2022 | 11:09 PM
flybd5's Avatar
most obvious?
iCarSoft makes a good unit. Clear all the codes, then run the car and see what codes it reports.
Old Nov 6, 2022 | 07:33 AM
Viking1's Avatar
Default Rough idle
iCarSoft arriving today and then we will see
any guesses out there ??
plugs,MAS,o2 sensor, cat is new so it’s not that
fuel injectors, gas cap good,
Old Nov 6, 2022 | 08:18 AM
flybd5's Avatar
If the icarsoft is arriving today you don't need guesses, just patience. The car will tell you what it thinks is wrong.
Old Nov 6, 2022 | 11:12 AM
Viking1's Avatar
Default 👍🏻 Yes
I’ll let you know
Old Nov 6, 2022 | 12:08 PM
ThorInc's Avatar
While you wait, fully charge your battery and then do battery reset (discribed in full detail on this very forum). Something that will help and also pass the wait period.
Old Nov 7, 2022 | 05:49 PM
Viking1's Avatar
Default iCarsoft tool says?
Cylinder 2 misfire detected
Honestly my first time using a diagnostic tool
I plugged it in turned on ignition cleared all faults (I think)
ran a quick test and fault came up Cylinder 2 misfire detected is this a bad plug? Wishful thinking
Old Nov 7, 2022 | 05:53 PM
flybd5's Avatar
Post the code(s) please, not the text description.
Old Nov 7, 2022 | 06:19 PM
Viking1's Avatar
Default Code
P0302-00 code ?
Old Nov 7, 2022 | 06:35 PM
ThorInc's Avatar
Swap the sparkplug from #2 with a different one and see if the misfire follows.
