Rough engine idle CK engine light on
Old Nov 7, 2022 | 06:48 PM
Viking1's Avatar
Default Rough idle barely runs
Ok I’m going to replace the plugs anyway 75,000 miles
probably ready This is my wife’s LR from new in 2007-8 babied. Hopefully it’s just a bad plug or coil
thanks for the input
Old Nov 7, 2022 | 06:49 PM
p_gill's Avatar
Check the wiring going to the coil.
It is possible that a small quadrupedal mammal has taken an interest in your wiring.
I can't be more specific about the species in question because someone here will have an adverse reaction.
Good Luck
PS there is some evidence that a failed Thermostat can increase the temperature of the coils and shorten their life. A broken Thermostat on a 3.2 is difficult to detect.
Old Nov 7, 2022 | 06:53 PM
flybd5's Avatar
Originally Posted by Viking1
P0302-00 code ?
P0302 is a generic code, it's likely the plug or the coil for that cylinder. Try what Thor suggested to narrow it down.
Old Nov 7, 2022 | 06:57 PM
Viking1's Avatar
Default Spark plug coil
Thankyou no critters under this hood engine is cleaner then most car exteriors but I’ll give the wires a close look over.
Thermostat humm ok I’ll start with plugs and coil and boot inspection
on Thursday earliest I can get to it any other tips on operating the analyzer ??
basic
plug in
enter vehicle info
click on Diagnostics
clear codes
start engine
quick scan
read codes
correct?
Old Nov 7, 2022 | 07:03 PM
Viking1's Avatar
Default Ok thankyou
Thor God of Thunder!
will do Thankyou
Old Nov 7, 2022 | 08:05 PM
flybd5's Avatar
basic
plug in
enter vehicle info
clear codes
start engine
quick scan
read codes
correct?
Assuming you chose the iCarSoft analyzer with the Jaguar/Land Rover option, you should be able to select that diagnostic and it will talk to the various modules in the car.
If you did not buy the right analyzer I would suggest returning it and buying the one that comes with the Jaguar/Land Rover diagnostics. It is a HUGE help compared to the garden variety OBDII codes.
Amazon Amazon
Also, when you get it go to the icarsoft website, download their application to your PC, connect your unit via USB and update it to the latest version of the diagnostic software.
Old Nov 7, 2022 | 09:02 PM
Viking1's Avatar
flybd5 Ty yes I purchased the correct analyzer I’ll update it tomorrow thanks
Old Nov 12, 2022 | 07:07 AM
Viking1's Avatar
Default 2008 LR2 #2 cylinder misfire
Hi Guys!
Ok I decided to replace all the plugs since they were ready 75,000 and install a new # 2 coil pak. Fully charged the battery. Cleared all faults started it up and no faults and running better then new! I got lucky. Thankyou both for your input and professional advise.
Old Nov 12, 2022 | 10:32 AM
merlinj79's Avatar
Yeah I do plugs around 60-70K now. I did all my coil packs at 150K, just for road trip reliability.
Old Nov 12, 2022 | 07:27 PM
Viking1's Avatar
Good idea do you prefer a specific brand coil pak? What about the pcv valve is it a good idea to replace it ? Thanks again
