signal light stay on
Old Jan 23, 2019 | 10:54 PM
redpepper70's Avatar
4th Gear
Default signal light stay on
LR2 2012 /
engine off / driver side turn signals, front and back, on solid.
engine on / still solid / turn signal works (solid but you could see blinking with stronger light)
I checked to make sure the lever was in the neutral position.
right side signal works fine, left side stay on solid engin on or off.
some forum mention about fault in the alarm/door lock control module.
anyone? where alarm/door lock control module is?
Old Jan 25, 2019 | 06:03 AM
ThorInc's Avatar
You likely have a short or exposed wire creating a bridge with your driver's side signals. You will have to trace the wiring to each light assembly looking at the wiring for damage. I would also check the relevant fuse box:
2006?2015 Land Rover Freelander (L359) Fuse Box Diagram » Fuse Diagram
Also see below (scroll down) for related threads; if that's the case, that's quite disturbing!
mathix
Jan 23, 2019 11:10 PM
bode61
Nov 25, 2018 08:08 AM
Gerard
Mar 1, 2013 01:20 AM
JavaRacer
Sep 30, 2010 07:15 PM
jm12503
Jan 23, 2009 02:26 PM
