Starting issue 2008
Old Sep 22, 2020 | 07:29 PM
Ajtcjtlou's Avatar
5th Gear
Default Starting issue 2008
I have replaced the starter on my 2008 landrover lr2 and it still isn't starting. Rolled out the start button also. Please help
Old Sep 22, 2020 | 11:17 PM
LR2driver's Avatar
Did you test the terminal at the starter to see if it's getting power when you press the start button?
Are you getting crank, or no-crank?
Did you check for OBD2 codes?
Old Sep 22, 2020 | 11:21 PM
Ajtcjtlou's Avatar
5th Gear
no crank
Old Sep 22, 2020 | 11:29 PM
LR2driver's Avatar
Originally Posted by Ajtcjtlou
no crank
I assume you already tested your battery and it's good.
If power is getting to the starter terminal and it's not cranking, you might have a defective replacement starter.
If power is not getting to the starter terminal, then check the relays/fuses in the ignition circuit.
Let us know the resolution.
Old Sep 22, 2020 | 11:42 PM
Ajtcjtlou's Avatar
5th Gear
we have checked the battery and fuses along with the relay
Old Sep 23, 2020 | 11:59 AM
flybd5's Avatar
Pull the starter and try to crank it by itself by pressing the starter button. If there is power going to it and it doesn't work then you got a bad starter.
Old Sep 23, 2020 | 12:01 PM
Ajtcjtlou's Avatar
5th Gear
We started the starter yesterday and now when I went to try and start it today and press the brakes the navigation would blink and then the radio said low battery. Which we have on the charger as we speak.
Old Sep 23, 2020 | 12:03 PM
Ajtcjtlou's Avatar
5th Gear
When we started the starter we manually did it
Old Sep 23, 2020 | 12:33 PM
flybd5's Avatar
Wait, what? You never checked battery voltage until now?
- What seems to be the problem?
- My computer is not working.
- Did you plug it in?
- Umm... Maybe that's it.
- There's your sign.
A bad starter can suck up the juice on the battery lickety split. Don't ask me why, but it happened to me and left me stranded some weeks ago.
MechanicRob
LR2
Dec 27, 2022 06:16 PM
slanginsanjuan
Jun 3, 2020 04:06 PM
Dawave
LR2
Jun 25, 2019 02:09 PM
vonrock
Dec 2, 2016 12:30 AM
jerrodp1
Dec 15, 2014 05:50 PM
