Steering Column Locked Appears On Dashboard
Old Dec 14, 2021 | 01:48 AM
ThorInc's Avatar
Originally Posted by zaidj109
ThorInc, Thanks for the link. I went through a bit of the links and a saw various things I could try and did, but nothing worked. That is until I saw a few articles mention the hammer trick. After a few hits, the steering lock was released and the car was able to be turned on.
Just adding what I did, in case this helps someone else.
I basically exposed the steering lock module, then held the hammer parallel to the module and struck the piece that I've circled on the image. After a few hits, I heard the locking mechanism release and immediately knew the car would turn on and it did.
Good news! So now that you can unlock the column it's time to install one of these, a cheap and easy solution for the future.
https://www.mk3.com/land-rover-freel...-lock-emulator
This will not work with an already locked column but will work fine with a functioning steering lock. Another solution is to use JLR SDD with required cable and simply remove/delete the steering column lock from the CCF (car config file) but that requires a steep learning curve and some monetary cost. The emulator is the way to go IMO. Good luck with whatever you choose!
One other thing, if you were to replace the steering column lock with a new or used one, you would still have to code it to the BCM using JLR SDD so, again, the emulator is a slam dunk solution.
Old Dec 14, 2021 | 01:52 AM
ThorInc's Avatar
Duplicate post.
Old Dec 14, 2021 | 09:48 AM
zaidj109's Avatar
5th Gear
Thumbs up
Thanks again for this insight. I really appreciate it.
Old Dec 14, 2021 | 09:50 AM
merlinj79's Avatar
Originally Posted by flybd5
Marine Corps Maintenance! Booyah!
Right tool for the job: Linear Impact Driver
Old Dec 14, 2021 | 10:33 AM
LR2driver's Avatar
Good news! So now that you can unlock the column it's time to install one of these, a cheap and easy solution for the future ... This will not work with an already locked column but will work fine with a functioning steering lock...
So you're saying this emulator should be installed on a working steering column to prevent the problem in the first place? It doesn't work if the column is already locked, which I thought was the purpose?
Old Dec 14, 2021 | 11:13 AM
ThorInc's Avatar
My research has indicated that it's a very common fail point for older FL2/LR2s and the proper solution can be quite expensive and time consuming. My research has also indicated that it does not always override the lock code stored in the BCM. Multiple threads on freel2.com, some with success and some without in using the emulator with the column already locked. Consider my suggestion as pre-emptive since this OP has the error popping up and it renders the car useless once triggered and he now has eliminated (in the interim) the error and the emu is a dirt cheap fix.
Old Dec 14, 2021 | 11:49 AM
flybd5's Avatar
I vote for a bigger hammer.
Old Dec 14, 2021 | 11:53 AM
ThorInc's Avatar
And I thought you had an emulator sitting on the shelf.
Old Dec 14, 2021 | 11:54 AM
flybd5's Avatar
I do! Next to the big hammer.
Old Nov 16, 2025 | 11:16 PM
Splicer's Avatar
The tamper-proof M6 bolts will be a b*tch to take out but when you do the module slides right out. The service manual says to use a stud puller. If you remove the steering column the job is much easier. This thread tells you what to do to lubricate it with, of all things, vaseline.
https://www.freel2.com/forum/post402011.html
I used a combination of a dremel and a multitool AKA vibratool to cut a slot and used a flathed srew bit in a small rachet. Worked like a charm and took about 45 minutes. A lot easier than pulling the whole steering column. I would note that when you reinstall the unit make sure it is in locked position with the locking pin out. I tried the other way and it showed the same old fault and it wouldn't start.
LRFAN
LR2
Jul 26, 2021 04:23 PM
nwr1967
May 10, 2021 08:16 PM
oliver1071
LR2
Jul 29, 2018 06:20 AM
andrewmcoffin
May 30, 2008 08:09 PM
