transmission fluid
Old Feb 15, 2017 | 03:41 PM
maxamilione's Avatar
4wd High
Default transmission fluid
So after all my work replacing the alternator i apparently nudged loose the transmission coolant hose so a fair amount of it spilled out over the last 3 days is there a way to fill this back up? any help would be appreciated. I have a 2008 lr2
Old Feb 18, 2017 | 09:49 PM
LR Techniker's Avatar
This vehicle uses an Aisin (not pronounced Asian) transmission. You need to find ATF that is Type T-IV. This is a very common fluid for Toyota, but is found on any vehicle using Aisin, including Volvo (which is where the LR2 motor comes from) some Audis and some Porsches. We use Idemitsu fluid, but any brand that meeds Type T-IV will work.
Old Dec 11, 2017 | 12:58 PM
a_wick_2010's Avatar
Watch this video
Get Mobil 3309 Auto Transmission Oil
Get several part accordingly
2 O-RIng
1 Washer
Good luck
Old Dec 11, 2017 | 03:55 PM
p_gill's Avatar
See picture below: This is what the manual call for (the Toyota T-IV is fine also)
if you ae going to change the fluid you should take a look at the UK site Freel2.com - View topic - Auto Gearbox Oil Change TD4 MY07-12
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
ferrelltodd
Aug 9, 2005 10:11 PM
