Transmission fluid fill plug access
Old Mar 10, 2019 | 07:27 PM
TouchdownAuburn's Avatar
Default Transmission fluid fill plug access
Recently I tried to check my transmission fluid level and ended up draining out about a quart before getting the plug back on. However, now I’m having trouble reaching the fill plug. Has anyone had this problem and how did you fix it? If I remove my battery is there anything I have to reset or can I just reinstall the battery afterward and be good to go?
Old Mar 17, 2019 | 09:14 PM
p_gill's Avatar
The fill port is a Torx T55
remove the air box to get to the fill port
see this link for more info
Freel2.com - View topic - Automatic transmission fill plug location
good luck
Paul
Old Mar 17, 2019 | 11:14 PM
It wasn’t that easy. The AC compressor is directly above the plug. There’s actually another plug on the side of the transmission above the left axle. Because of the angle, it took awhile to fill but it was easier than removing the air filter box and the AC compressor. Even then the plug on the top is partially under a mount.
Old Mar 18, 2019 | 11:43 AM
p_gill's Avatar
Take a look at this PDF
Can you identify which port you used?
File Type: pdf
stillruns
Sep 8, 2018 08:18 PM
dlorraine
Aug 25, 2018 12:40 PM
DAMINK
Aug 18, 2015 04:09 PM
jdelp
Sep 20, 2007 11:23 AM
