Turbocharger failure
Old Jan 2, 2022 | 09:50 AM
merlinj79's Avatar
Originally Posted by guy
Another common issue on the earlier models of the turbo on the ecoboost engines was a crack in the casing. I wonder what would have been the cause for that?
I heard anecdotal stories of shops with scrap bins FULL of ecoboost turbos and heads in the early days. I actually wanted to get a newer LR2 but opted out due to the ecoboost... at least the new defender has some real engine options.
But due to some troublemakers… look what I found: https://www.dieselusa.com/garrett_ec...ochargers.html
sigh/. If I could only upgrade the engine…
Garret makes aircraft engines, so they should do a decent auto turbo.
Old Jan 2, 2022 | 10:27 AM
flybd5's Avatar
Garrett doesn't make reciprocating engines, only turbine engines.
Old Jan 2, 2022 | 10:28 AM
flybd5's Avatar
You can. But there is a saying with experimental homebuilt aircraft builders. Do you want to build, or do you want to fly?
Old Jan 2, 2022 | 10:38 AM
merlinj79's Avatar
I know, a turbo charger is within that wheelhouse. I was referring to the turbo, not the recip engine.
Old Jan 2, 2022 | 04:55 PM
guy's Avatar
guy
@merlinj79 , did you see my post about this very situation with the 1st gen ecoboost… at roughly 100,000 kms I got the replacement (and updated) engine from the excellent LR warranty. But it wasn’t the turbo…. it was the cam shaft and valves.
detaildesign
Apr 19, 2016 01:32 PM
Adsan1280
Jan 2, 2013 02:52 PM
ZB-30
Nov 28, 2012 12:00 PM
Adsan1280
Engine & Internal
Jun 13, 2011 12:38 PM
tap121
Mar 31, 2007 12:07 AM
