What bad upper engine mounts/insulators look like...
Old Dec 29, 2023 | 06:21 PM
flybd5's Avatar
Default What bad upper engine mounts/insulators look like...
I just changed my upper engine mounts (what LR calls "insulators") They were most definitely shot. For those of you wondering what I mean by that, here's the signs.
This mount is below the arm-style mount at the top of the engine. It bolts to the frame, and a bracket that bolts in four places to the engine has a single bolt to this. On the left is obviously the new mount, on the right the old mount. Definitely shot.
And this is the old arm-style mount. I had changed it two years ago but because I did not know the lower one was shot it died an early death. You should not be able to see through the rubber.
Tomorrow I will change the lower mount, will post a pic of that when I am done.
Old Dec 30, 2023 | 11:27 AM
merlinj79's Avatar
Yes a bad upper mount strongly implies bad lower mount(s). At this point (age and mileage) I'd just replace all.
Replacing mounts will notably improving shifting, as will replacing auto-trans fluid.
ononomos
May 27, 2021 07:01 PM
acg
Apr 26, 2019 11:26 AM
ebg18t
May 28, 2012 08:57 PM
EricTyrrell
Nov 21, 2011 12:18 AM
yloDiscoII
ROAMING WITH FRIENDS
27
Aug 21, 2010 07:18 AM
