Worn Wire Harness
Old 06-20-2021 | 12:46 PM
merlinj79's Avatar
Default Worn Wire Harness
I replaced my PCV/camshaft cover assembly today.
In the process I noticed that the wire harness leading to the small electrical connector next to the PCV valve was deteriorated... the loom had disintegrated, and the insulation on each of the three wires had also disintegrated, leaving mostly bare wires. The wire bundle is twisted, so not sure how they didn't short out, maybe just air gap and oil residue. No codes or engine trouble. I'm not sure what sensor that is.
Also not sure why they deteriorated, maybe chemical exposure (brake fluid?). They might have rubbed on the PCV valve itself, the copper wire was perfectly intact.
I wrapped each wire in electrical tape, then some more around the bundle, then a piece of loom over that.
Anyway something to keep an eye on.
ThorInc (06-20-2021)
Old 06-20-2021 | 02:45 PM
ThorInc's Avatar
Now I have to go check!
That should not happen in my opinion.
Old 06-20-2021 | 03:43 PM
merlinj79's Avatar
Yeah, I'm thinking chemical exposure, I don't see how chaffing would remove all of the insulation evenly around the wires. I also don't think the PCV valve should vent hot vapor to the engine bay, but maybe that's a failure mode.
Old 06-20-2021 | 10:08 PM
flybd5's Avatar
I haven't seen something like that in a long time. It's one thing for the insulation to degrade, but to be removed like that requires some serious chafing in a very specific way.
Old 06-20-2021 | 10:30 PM
LR2driver's Avatar
Rodents
Old 06-20-2021 | 10:42 PM
flybd5's Avatar
Originally Posted by LR2driver
Rodents
Give the man a ceegar. I would bet good money this is the right answer.
Old 06-21-2021 | 08:03 AM
ThorInc's Avatar
Unless you left the cover off or something was trapped between the cover and harness for a bit...........it's likely mice but...........you should see, at the very least, droppings. But critters does make sense.
Old 06-21-2021 | 08:34 AM
flybd5's Avatar
You won't see dropping in the engine compartment. I had one of those mice in the cockpit of my glider and the inspector said he saw it. It was just specks of dark on my sling seat.
Old 06-21-2021 | 08:54 AM
merlinj79's Avatar
Didn't think of that, the car is a daily driver and goes on most vacations so it doesn't sit idle hardly at all. Maybe a week when we go overseas.
Must be some tasty insulation.
zski128
06-04-2021 06:10 PM
TheMgmt
10-22-2018 12:41 PM
Summit rover
04-20-2012 10:25 PM
ajh
10-29-2007 02:17 PM
Quick Reply: Worn Wire Harness
