05 LR3 fuel injector cleaning
Old Nov 13, 2019 | 11:39 AM
tboard24's Avatar
Default 05 LR3 fuel injector cleaning
I have an 05 4.4 LR3 that has the schrader valve at the fuel rail. Been having multiple cylinder misfires after getting gas at a suspect gas station. I bought a chinese non dismantle canister cleaning kit off ebay that didn’t have the right fitting for the schrader valve but I managed to cobble something together with different hoses and fittings. Hooked itup and managed to get the rover started but noticed gas spewing from one of the fittings so I shut it down. So I got a smaller ID fuel hose and a much tighter connection but when I hook it back up I can't get it to starton the pressurized canister at all now. I've tried 50-75psi. If I put the fuel pump fuse back in it starts right up. I even tried leaving the canister hooked up, starting car and pulling fuel pumpfuse and it just dies.
On this forum or a different one I read of another person with an 05, the only MY with the schrader valve on the rail, who had the same problem when trying to do the cleaning service at the valve. The hose would pressurize but the car wouldn't start off the canister.
Is the Schrader valve meant only to check the pressure but not to service it? Is there a better spot to do the service on a MY 05?
Any advice?
Old Nov 13, 2019 | 02:30 PM
abran's Avatar
Schrader valve works for service. You fitting is not actuating the center plunger. You can go in at the fuel rail, but need a special Ford adapter for that.
Old Nov 17, 2019 | 03:26 AM
Globetrotter448's Avatar
Take the centre plunger out like you would for a tyre
okdiscoguy
Jan 16, 2024 04:31 PM
JUKE179r
Build Threads
169
Dec 29, 2023 05:49 AM
luxury1
Jan 17, 2009 07:59 PM
luxury1
Jan 29, 2008 10:14 PM
GodSavetheQueen
Jan 9, 2008 12:15 PM
