12000 Harbor Freight winch
Old May 22, 2018 | 08:16 AM
MrWesson's Avatar
I too plan on the hidden setup. I just need to find a mount system. I may pick up the Harbor Freight universal plate and modify it to fit like some II guys did. But while it worked for them, not sure if it will on the 3. Need to investigate when I have time. I can weld, so there will probably end up being some custom fab fun when I do it.
I have an LR3(the one pictured).
I might have been the first to modify it to work with it but not sure.
If you go through my posts there's a semi-how to.
Depending on how much a hidden winch setup mount costs it might be worth your time. I haven't put too much stress on mine just doing straight pulls and using it to pull other people in mild stuck situations(in FL). I wouldn't do it if I lived in the mountains and had to do alot of sideways pulls on slopes.
YMMV.
EDIT.. I googled it and found this one for $499.99 and would just pony up for that unless you already have a welder or want one(and have spare time).
https://voyagerracks.com/land-rover-...n-winch-mount/
Old May 22, 2018 | 09:18 AM
Kdo58's Avatar
For the mall crawlers
Insta-Winch | Rough Country Suspension Systems®
Old May 22, 2018 | 05:04 PM
DakotaTravler's Avatar
@ MrWesson - I already have a welder and access to a shop (for farm equipment). So I think I am going to try the HF plate as a starting point. Cut, weld, reenforce, modify, etc. $500 is just a bit much but if the HF plate will simply not work out, then I will probably go that route.
@ Kdo58 - thats awesome! lol
Old May 22, 2018 | 06:08 PM
m_lars's Avatar
I’ve got a HF mount with a smittybilt 10k on my 3. We just used it a bunch getting through snow above 9000 feet in the Uintas here in UT.
Old May 24, 2018 | 07:40 PM
RickyN29's Avatar
Originally Posted by Kdo58
Ok I nearly died laughing with this
Old May 26, 2018 | 10:16 AM
spannermonkey's Avatar
That's so funny , are these muppets really that fickle
dusty1
Jun 13, 2018 11:11 AM
acg
Mar 7, 2014 04:59 PM
grandkodiak
Oct 2, 2012 03:25 PM
lipadj46
Nov 19, 2010 06:40 PM
stu44mag
May 25, 2009 09:53 PM
