2005 Land Rover LR3 Fault Messages
So I went to start my truck and I had the following messages on my dash...
Transmission fault limited gears available... Suspension Lowered...Parking Brake Fault...HDC System Fault .... I powered the truck off and started it back and the messages went away today I started it and the same messages are back... I replaced the battery and still the same messages
Any help would be appreciated
Thanks
Thanks
I will guess battery, brake pedal switch under the dash, or a bad brake light bulb.
Again, just guessing.
Let us know what it turns out to be ( so we can add to the body of knowledge here on the forum)
Jeff
General Disclaimer: "I may be Wrong."
Jeff
You need to go over the cables, completely. Including where the negative attaches to the body. And at the battery there is a plastic black housing inline with the positive lead. Inside is a fuse. All these points can have corrosion and cause issues. For me it was a corroded fuse. Cleaned it up and problem free since.
Edubo7 (03-05-2020)
kbarker27
10-13-2023 04:03 PM
06Range
05-08-2013 09:01 PM
