2005 Land Rover LR3 Fault Messages
Old Oct 22, 2018 | 09:06 PM
Romelo357's Avatar
Default 2005 Land Rover LR3 Fault Messages
So I went to start my truck and I had the following messages on my dash...
Transmission fault limited gears available... Suspension Lowered...Parking Brake Fault...HDC System Fault .... I powered the truck off and started it back and the messages went away today I started it and the same messages are back... I replaced the battery and still the same messages
Any help would be appreciated
Thanks
Old Oct 22, 2018 | 09:36 PM
Need to get the codes pulled with a land rover specific code reader (not a cheapie obdII) so we can see what's going on. It could be anything from corroded wiring, a wet connection, to module failure.
Old Oct 30, 2018 | 09:43 PM
Romelo357's Avatar
Well it's in the shop now... So we will see what's the issue is
Old Oct 31, 2018 | 06:48 AM
Rufflyer's Avatar
I will guess battery, brake pedal switch under the dash, or a bad brake light bulb.
Again, just guessing.
Let us know what it turns out to be ( so we can add to the body of knowledge here on the forum)
Jeff
General Disclaimer: "I may be Wrong."
Old Oct 31, 2018 | 06:52 AM
Romelo357's Avatar
Hey I've tried a new battery and new brake light switch from land Rover and it didn't fix so now it's in the shop at British Motorworks so we will see will post results when I find out
Old Nov 2, 2018 | 05:34 PM
Romelo357's Avatar
Update.. just got my truck back had a bad postive battery cable and I needed software updates after all codes was cleared cost $130 so far so good
Old Nov 4, 2018 | 05:42 PM
Romelo357's Avatar
Welp that didn't last long worked great for 2 days now back to the crazy codes car back in shop
Old Nov 4, 2018 | 06:44 PM
DakotaTravler's Avatar
You need to go over the cables, completely. Including where the negative attaches to the body. And at the battery there is a plastic black housing inline with the positive lead. Inside is a fuse. All these points can have corrosion and cause issues. For me it was a corroded fuse. Cleaned it up and problem free since.
Old Nov 11, 2018 | 07:53 PM
Romelo357's Avatar
Well seems like the problem is fixed.... ABS computer had a corroded ground wire... Replace the wire and been running fine now for a week no issues
mroorda
Aug 23, 2020 06:51 AM
tchaudhry10
Apr 18, 2019 04:28 PM
06Range
May 8, 2013 09:01 PM
LambLakeLR3
Dec 7, 2011 08:00 AM
