2005 LR3 headlight Problems 🤬
Old Sep 2, 2019 | 12:44 AM
Captainmorgan's Avatar
6th Gear
Default 2005 LR3 headlight Problems 🤬
Changed headlights (as I have done MANY times before ) however they turn off on their own after putting vehicle into drive or reverse. This happens either immediately or after about 10 seconds after starting to drove. They are set on auto. Battery was recently changed as well however everything else working fine. Any suggestions ? Thanks - first time on this forum 👍
Old Sep 2, 2019 | 05:10 AM
Globetrotter448's Avatar
when you say headlights, do you mean globe/bulbs. If so, they may be wrong type.
Old Sep 2, 2019 | 10:10 AM
6th Gear
Yes bulbs ..... however same bulbs as have always been used and I have done this procedure many times before. Somehow putting vehicle into drive/reverse is affecting the headlights
Old Sep 2, 2019 | 11:14 AM
DakotaTravler's Avatar
Sounds like a loose connection and the jerking/movement is connecting/disconnecting them. I can't really see how swapping lamps would be any sort of issue.
Old Sep 2, 2019 | 12:00 PM
6th Gear
Ok thanks ..... I’m going to re-do everything and try again .... they housing clip was acting up a bit so perhaps it was wiggling a bit
Old Sep 2, 2019 | 10:24 PM
6th Gear
Worked for 5 minutes in drive and then both out a exactly the same time ..... so doesn’t sound like connection or fyse or wrong bulbs 🤬
Old Sep 2, 2019 | 11:19 PM
Are they standard bulbs or extra upmarket wattage bulbs as the system maybe drawing too much current so disables itself
Old Sep 3, 2019 | 07:08 AM
6th Gear
Good question..... I thought they were the exact same as I had previously but will double check. Thx
Old Sep 3, 2019 | 06:03 PM
enb54's Avatar
X2, these machines are very finicky and if you notice the size of the wires, I'm sort of surprised they can even handle the H7...
Old Sep 6, 2019 | 05:10 PM
abran's Avatar
I would check your tailight bulbs too.
bribake
Mar 19, 2017 07:23 AM
Eurobahn LandRover
Detailing
Jan 18, 2016 04:00 PM
slabrat
Detailing
Sep 26, 2013 12:16 PM
starcraft1
Dec 4, 2012 07:31 PM
redroverlr3
Mar 29, 2011 08:22 PM
