2006 LR3 Ashtray
Old Jan 6, 2013 | 01:29 PM
Stillwaters's Avatar
4wd High
Default 2006 LR3 Ashtray
Okay, here's an interesting problem.
The other day my ashtray door popped open on my 2006 LR3 (we never use the ashtray). I tried to clsoe it and it just popped right back open. I figure that some sort of latch must have given way. Before I take it to the dealership for some horribly overpriced repair, does anybody have any info on this?
Old Jan 6, 2013 | 02:10 PM
ghengis86's Avatar
No, sorry. Mine did the opposite, where the spring broke and won't pop open at all. Have to pull it. I wouldn't take it to the dealer to fix, unless you're really particular about it. You can take out the sping after pulling the tray out completly. THere are little plastic retaining tabs that keep it in the recess.
2005-2008 LR3 Ashtray Assembly
cheaper here:
Ash Tray (Genuine Part # FKB500050WBQ) - Land Rover interior panels/seats from Atlantic British
Old Jan 6, 2013 | 05:36 PM
threalassmikeg's Avatar
make sure you order the green escutceons for the aux port and cigarette lighter. you will not be able to re-use them.
Old Jan 9, 2013 | 05:47 AM
4wd High
cheaper here:
Thanks, I'll try to get it out this weekend. Heck, it seems the part alone is nearly $200.00 IF you can find it...
Old Jan 9, 2013 | 07:30 AM
ghengis86's Avatar
Have you downloaded the workshop manual yet? The removal procedure is in there with diagrams and steps.
Old Jan 9, 2013 | 10:57 AM
wheelgarage's Avatar
It seems to be a common problem. My spring just popped out. I tried to work it and I heard the spring fall in the back.
British Utah has the assembly for $52, which I will be ordering soon. What is a Biatch, is that the entire center console will need to be removed. There is a screw on the very bottom that holds it in...
Old Jan 25, 2013 | 01:06 PM
4wd High
Well, after messing around with it for about an hour, I just ran a small tap screw through the side and secured it in the closed position. We never use the darn thing anyway...
angasreid
Dec 7, 2018 09:07 AM
nelsontod
May 21, 2012 10:51 AM
Classklown90
Oct 27, 2009 04:26 PM
tyworthington@gmail.com
Apr 23, 2009 09:39 AM
brw1982
Aug 15, 2008 06:40 PM
