2006 LR3 notchy, binding steering
Old Aug 14, 2017 | 04:01 PM
tommizerek's Avatar
3rd Gear
Default 2006 LR3 notchy, binding steering
Hey everyone....I have a 2006 LR3 with 116,000 miles on it my steering became very notchy, I've been told that it's probably the lower steering shaft, I cleaned and lubed the u-joint, it seems like it got a little better, but what I've realized is that the notchiness happens after driving for a while, and doesn't happen while the car is stopped and wheel is turned, ps fluid looks fine, the ps pump is not making any noises and the belt seems tight....I figured if it was the u-joint on the lower steering shaft it might get better with driving for a while, but it's the other way around....very confused....any suggestions?????
Old Aug 15, 2017 | 02:08 AM
DiscoCam's Avatar
You are more likely to get an answer if you post on the LR3 forum. But it sounds like you need a steering rack.
Old Aug 15, 2017 | 09:28 AM
WNYErikDiscoII's Avatar
Former Sponsor
You need one of these, trust me, been there done that
https://www.lucky8llc.com/products/l...column-genuine
tommizerek
Aug 8, 2017 02:57 PM
Glen11
Jun 11, 2014 08:56 AM
Mountain Goat
May 23, 2012 12:28 PM
bothomasmusic
May 24, 2011 12:47 PM
IanWhitefeather
Nov 13, 2010 05:45 PM
