2006 LR3 starting issues
Old Feb 16, 2016 | 10:18 PM
EstorilM's Avatar
Perhaps, but I have yet to see it mentioned on forums or re: diag, only mentioned on parts websites.
FWIW my GFs diesel jeep (2.8 turbo, '05.. Fairly modern design) has a MAP sensor and it gets NASTY thanks to tons of erg/recirculating pcv and other oil vapors through intake system. Causes lots of boost and other engine problems but it is the primary air/fuel sensor as there is no vacuum in a diesel thus no MAF sensor (hers has a MAF technically but it's only used for EGR and emissions).
Sounds like the AJ 4.4 uses as cross correction against MAF, but again I've heard zero mention of it.
Old Feb 16, 2016 | 10:25 PM
jafir's Avatar
Since it threw multiple codes for it, it's certainly a good place to start troubleshooting. I'm not saying replace it. Unless it's cheap.
Old Feb 29, 2016 | 02:26 PM
jlmartin42's Avatar
7th Gear
Update: I tried cleaning the EGR valve which didn't help the issue, so I ended up replacing it. Surprisingly, it seems to have fixed the problem. Took all of 30 minutes and $200. I replaced it last Saturday and have had no problems since (and I would have had problems by now). Just wanted to post an update in case anyone in the future has a similar issue.
comleader
Sep 29, 2022 09:32 AM
cmpintosantos
Sep 24, 2018 02:32 PM
shedlock2000
Aug 4, 2015 04:50 PM
Albertaguy
Oct 30, 2010 09:51 AM
Bean
Jul 15, 2010 11:13 AM
