2006 LR3 Wont Drive in Any Gear
Old Oct 11, 2018 | 08:53 PM
  #51
5280LR3's Avatar
Originally Posted by kenneypj1
i think that cleaning this out of the valve body would have helped its original condition, but I don't think that it would have cured it. This transmission had worn clutches and heat spots on the steels. The presence of this debris in the valve body is just an indicator towards the the root issue. Additionally there were pieces of clutch disc in the oil pump and front bearing which would have caused issues had they not been taken care of.
Not to get into the chicken or the egg debate... but... I would bet the heat spots and clutch plate damage (also likely from heat) are from the transmission not having sufficient fluid to operate correctly in the first place. Think of a driver learning to drive a manual transmission car. They slip the clutch and rev the engine up to keep it from stalling. This creates a tremendous amount of heat. You've probably seen pressure plates with heat spots in them and the clutch disc worn out or burned up. It's basically the same thing except you're using fluid and a pump vs your leg to set the plate(s) into lockup to move the vehicle. Who knows how the previous owner treated the transmission when it started slipping, just mash the gas and see if it goes... or just drove it until it wouldn't move anymore? I could see this causing the damage you described, especially with the weight of these LR3's. I wouldn't think this is normal wear for a trans with only 144k
So, in your case, the rebuild may have been required from the abuse of low fluid and possibly faulty solenoids. I guess my point of this reply is that just because these transmissions are not working correctly, it doesn't mean a full rebuild is required. This may have been true many years ago when transmissions were shifted by vacuum solenoids, etc, but with computers and electronic valves controlling modern "sealed for life" (yeah, right) transmissions there are many more things to consider while diagnosing issues.
Old Oct 13, 2018 | 12:00 PM
  #52
kenneypj1's Avatar
I agree that the clutch wear and heat spots are probably from abuse with low fluid. I think the fluid got low, the person kept driving, the clutches burned and shredded and some of those pieces clogged the valve. Bottom line is make sure you have enough transmission fluid. It would be worth starting by just replacing the solenoids and rebuilding the valve body except that if that doesnt work you may have to do it again due to new junk being introduced into it during testing.
The transmission took just over 1 more quart of fluid. I took the LR3 out for a drive and it seems to be working well! Does shift at odd times (nothing crazy) but I think that may be part of the adaption process. I also need to replace the pan gasket and drain plug as I have a small leak. Probably from repeated removal and re-assembly. I will post all the parts I used along with pricing at some point. Total cost is probably around $1600 including the 16qts of Mercons SP and 3qts of Penosil ATF1 fluid I have purchased
Next up is fixing the emergency brake: took off the passenger side disc and it's just gone. Like cable cut and hardware/shoes missing.
Old Oct 13, 2018 | 10:52 PM
  #53
5280LR3's Avatar
That's great news. The adaptation can take up to a few hundred mile to sort out. Watch your solenoid amperages to make sure they are functioning correctly. There was/is a trans software update you could try if things don't straighten out.
The parking brake... is the cable housing still attached with the nut to the backing plate? That's an ugly job to swap out that parking motor and cables assembly. Not nearly as involved as a trans rebuild for sure, so maybe it'll seem like a breeze. Wiggling the box out of the chassis and the cable routing is a PITA. I've got a couple good complete assemblies if that's what it comes down to. No brakes shoes or small hardware tho...
Old Oct 13, 2018 | 11:07 PM
  #54
abran's Avatar
I hate fixing the parking brake module. One of my least favorite jobs.
Old Nov 3, 2018 | 04:43 PM
  #55
kenneypj1's Avatar
After losing my key and finally getting a replacement I just need to put the final touches on the transmission, i.e. replace the pan gasket and drain plug to eliminate leaks. I will let you all know if I have any more problems with this transmission.
E-brake: I replaced the hardware and pads on both sides, and the cable on the passenger side. I was able to do it without removing the whole assembly, which I am thankful for. After replacing the pads and hardware the brake still would not try to function. I was getting an error that the switch was in an undefined position, so I took the switch apart pressed down on the little rubber contacts inside and the parking brake engaged! Put it back together and now I have a working epb!
Now to fix the washer fluid leak, get it inspected, replace the diff and transfer case fluids, replace the coolant, and maybe fix the sunroof (it does not operate when I press the switch. I can get it to go through one full cycle with the reset procedure but it will not function normally.)
Old Nov 12, 2018 | 04:00 PM
  #56
kenneypj1's Avatar
I am using a Ford Raptor oil pan and filter along with a Fel-pro gasket. After replacing the gasket a second time i'm still getting fluid coming out. Ive looked closely and it appears to be coming only out of the pan gasket. The fel-pro gasket is an aluminum one while the one that came with the ZF rebuild kit is a more traditional gasket material. Anyone have any input on what gasket they have successfully used with their metal oil pan?
Old Nov 13, 2018 | 09:16 AM
  #57
abran's Avatar
I use the fel pro aluminum with rubber overmold.
maybe the rubber got damaged?
Old Nov 14, 2018 | 03:19 PM
  #58
kenneypj1's Avatar
Hmm, maybe I have a scratch on the mating surface. It is possible I damaged the gasket as I was in a bit of a rush, but this is the second one leaking from the same area so I'm thinking it has to do with the pan or casing and not the gasket. Good to hear you are using the Fel-pro successfully!
Old Nov 14, 2018 | 10:55 PM
  #59
5280LR3's Avatar
Ford BL3Z7A191C. Had the pan off twice and reseals just fine. Aluminum with rubber beads on both sides. $14.00 on Rockauto.
Old Nov 19, 2018 | 04:29 PM
  #60
kenneypj1's Avatar
That’s for the info everyone.
I pulled the pan off again (I’m getting sick of the smell of transmission fluid at this point) and it looks like I’ve been over-torquing the screws I can’t get a torque weeny on, causing the aluminum gasket to split at the seams. Overall this raptor transmission pan, b&m drain plug, and felpro gasket have been more work than they are worth. It was an attempt to save some money, but it has backfired. I also tried using the gasket that came with the zf rebuild kit, but that didn’t even come close to sealing. The biggest problem that I see with this pan is that it has a flat gasket surface rather than the ridged surface on the metal conversion pans you can buy from Atlantic British or lucky-8. Other people have done this successfully, but to me, at this point, it doesn’t seem worth the slight savings, especially when considering you need to modify the heat shield.
I ordered a steel pan kit from lucky-8 to resolve the issue and get me on the road.
I will be posting a parts list and cost list for the whole rebuild at some point for all those interested in attempting the self rebuild in the future
