2007 Land Rover lr3 ( suspension problem)
id suspect the compressor if there is an exhaust valve fault present.
but if you think you have an air leak you should really confirm.
step 1: park on flat area at off-road height overnight with battery disconnected-> this will stop the vehicle from lowering on its own.
step 2: record your levels
step 3: morning after-> check your levels and compare to what you wrote down.
if there is a huge difference at one corner -> check its feed line and air bag
if front or rear is dropped -> check that valve block.
if no drop-> you have no leak.but may need to repeat again set to normal height. bags can leak at different heights.also cold weather can effect them as well.
kiddhan625
03-30-2014 04:15 PM
joeekrub
01-29-2013 08:47 PM
beaubrant
10-25-2012 10:13 AM
Treendog
07-11-2008 01:48 AM
