2007 Land Rover lr3 ( suspension problem)
Old Mar 23, 2018 | 04:00 PM
abran's Avatar
Also, Are you sure its an actual "hitachi" or a Hitachi "type" compressor. Dorman makes a crappy one that is a Hitachi "type". I have also seen, or better yet" heard" a fake AMK that was terrible. Sounded like crap.
Bearmach sells an AMK type compressor that is actually pretty good.
Old Mar 23, 2018 | 06:18 PM
Fahadazim's Avatar
7th Gear
I confirm from my parts supplier, it is hitachi, someone told me it could be a block that sit between reservoir and compressor, what do you think
Old Mar 23, 2018 | 07:11 PM
bob.258's Avatar
4wd High
id suspect the compressor if there is an exhaust valve fault present.
but if you think you have an air leak you should really confirm.
step 1: park on flat area at off-road height overnight with battery disconnected-> this will stop the vehicle from lowering on its own.
step 2: record your levels
step 3: morning after-> check your levels and compare to what you wrote down.
if there is a huge difference at one corner -> check its feed line and air bag
if front or rear is dropped -> check that valve block.
if no drop-> you have no leak.but may need to repeat again set to normal height. bags can leak at different heights.also cold weather can effect them as well.
Old Mar 26, 2018 | 07:14 PM
Fahadazim's Avatar
7th Gear
Well finally fixed it, it was a defective compressor, got a replacement today and so far everything works fine thanks for ur help guys.
Old Mar 26, 2018 | 07:37 PM
abran's Avatar
I was hammering on that. like any manufactured part, there can be failures.
cmshoot
Jul 27, 2017 04:11 PM
kiddhan625
Mar 30, 2014 04:15 PM
joeekrub
Jan 29, 2013 08:47 PM
beaubrant
Oct 25, 2012 10:13 AM
Treendog
Jul 11, 2008 01:48 AM
