2008 LR3 bolt and spacer identification
Old Apr 19, 2024 | 03:58 PM
rlaszewski's Avatar
Default 2008 LR3 bolt and spacer identification
Backing out of the driveway the other day, I found this bolt and washer from under the car. Any idea where it may have come from?
I had not done any work lately, so no obvious place to start. In November, had the transmission cooler lines replaced and transfer case replaced.
Need help in knowing where to look for where this may have come from. Head is 10mm and bolt is about 2 1/8" long.
Old Apr 19, 2024 | 06:05 PM
DakotaTravler's Avatar
I tend to think that is an exhaust manifold bolt.
Old Apr 21, 2024 | 05:48 AM
P-Bod's Avatar
Yes, definitely exhaust manifold. I had one missing on the front left cylinder when I bought my 07.
4646064 Manifold Bolt
4642648 Exhaust Manifold Spacer
Old Apr 24, 2024 | 10:31 PM
AdmiraLR3's Avatar
I have to tighten that front left bolt every two years coming out of winter. Can be accessed through the wheel well with a long extension and wobble joint
Old Apr 25, 2024 | 11:43 AM
rlaszewski's Avatar
Default Manifold Bolt
Thanks all for the advice. Really hard to even get a visual on all of the bolt locations, and I still have not located missing one.
I guess will have to remove wheel well to see.
Riese
LR4
Mar 21, 2024 10:05 PM
Dai20bt
Feb 18, 2024 06:31 PM
arkrover10
Range Rover L405 (Fourth Gen)
May 31, 2023 10:55 AM
Paul1987
Jul 8, 2021 06:58 PM
Lisa Bunch
Apr 2, 2019 10:08 PM
