265 60 r18 vs 275 65 r18
Old Aug 9, 2019 | 12:05 AM
rsvrman's Avatar
Default 265 60 r18 vs 275 65 r18
Basically looking at a 30.5” vs 32” tire.
Im going to be in OHV parks near me, (CA-Bay Area) some small water crossings. Moderate rocks (not extreme at all)
I have a newly acquired lr3, which has the 265 60 r18. Wrangler Duratracs on it. These don’t rub and from my limited knowledge they won’t bottom out on the bump stops should I have a suspension issue. (Please correct me if I’m wrong)
Ive been eyeing a 32” as in the title, but it would theoretically only provide a small lift (.75 above and below roughly) on lift.
As the 32” tires will require the bump stock kit to prevent me from being stranded in the event of a failure, I’m trying to weigh out the pros and cons.
Ive been very happy so far with what I have, but haven’t pushed it. I also will be soon daily driving the rig 40miles a day.
Just curious what others with more experience off-roading would consider as I’m still very green to off-roading.
Added - have that IIdtool
Old Aug 9, 2019 | 01:19 PM
abran's Avatar
I would stick with your size, less issues if you go to bump stops.
Old Aug 9, 2019 | 07:33 PM
Also easier on the commute. You can feel a power difference between the smaller tires and 32’s even more dramatic when you go to 33’s
Old Aug 9, 2019 | 08:01 PM
rsvrman's Avatar
Thanks for the responses. I’ll keep the same size for now then. It looks like the stock tire size is 255 60 r18, which puts it at a 30” tire, but the 265 60 r18 is a 30.5” tire. So I currently don’t have stock on the vehicle. Do you know what is the largest tire size I can run on the stock bump stops?
Old Aug 10, 2019 | 02:27 AM
loanrangie's Avatar
265/65 is about largest you'll fit as a spare at a squeeze, been running 265/60 for almost 2 years and find them an ideal size.
Dv8er
Jun 20, 2022 05:27 PM
joe black
Oct 24, 2014 06:06 PM
FlyingZebra34
Aug 31, 2012 07:33 PM
jpluncford21
Mar 7, 2011 06:48 AM
Camdisco24
Mar 7, 2008 12:19 PM
