4.4 engine swap
Old Sep 3, 2023 | 08:52 AM
EastCoast's Avatar
Default 4.4 engine swap
What needs to be replaced when doing an engine swap or is it just plug and play. I would assume ecu's but a detailed list (if any) would be appreciated!
Thanx
Old Sep 3, 2023 | 09:07 AM
abran's Avatar
It’s plug and play, but while the donor motor is on the stand you should change every seal possible, seal up the front cover(you have to remove the crank pulley), and put new coolant pipes and spark plugs.
All that stuff is easier to do on the stand versus in the vehicle.
Mr George
Nov 27, 2022 07:16 AM
merebel
Nov 1, 2021 07:20 PM
reporob
Mar 2, 2014 03:00 PM
98HSE46
Nov 4, 2012 04:49 PM
03discoman
Dec 18, 2009 09:29 PM
