4.4 V8 Over Advanced P0011 P0021
Old Feb 11, 2019 | 11:02 AM
Jewls's Avatar
4th Gear
Default 4.4 V8 Over Advanced P0011 P0021
Hello All,
I'm very new to the site as I'm struggling to find answers on why I'm getting the P0011 & P0021 Intake camshaft position timing-over-advanced
I've, changed the crank sensor, also changed the thermostat housing, water sensor and thermostat, as also having a P0128, so wondered if that was playing up with the emissions and timing, changed the spark plugs, coil packs..
Looked for air leaks etc, cleaned the MAF and the throttle body, and each time after doing any work, i clear all codes, after printing them off.. all was looking good, then engine management light was on after filling up with petrol (wasn't on before stopping) and turning in to the road i live, the "engine system fault" popped up on the screen..
Has any of you seen this issue before? sadly here in the UK, there isn't many people I can ask about the 4.4 v8 or I'm just struggling to find them??
Best wishes,
Jewls
Old Feb 11, 2019 | 02:16 PM
abran's Avatar
Sound slike a cam sensor. Have you tried swapping that out?
Is the engine running smoothly?
Old Feb 12, 2019 | 05:45 AM
Jewls's Avatar
4th Gear
I didn't think it could be that, as I have the same issue on both banks, hence doing the crack sensor??
Old Feb 12, 2019 | 06:04 AM
I'm with Abran on the cam sensor.
Old Feb 12, 2019 | 07:04 AM
Jewls's Avatar
4th Gear
So your saying to change both cam sensors? Are they a common issue on the v8's, just seems odd, both report a problem at the same time??
Old Feb 12, 2019 | 12:29 PM
abran's Avatar
Not a common issue in my experience. The other option is that your chains skipped a tooth or the tensioners are bad.
Any rattle noise at cold start up?
airisgood01
Mar 17, 2020 07:02 AM
DeepBlueWater
Nov 22, 2019 07:51 PM
4Low
Sep 17, 2014 03:28 PM
Chris-bob
Aug 11, 2011 01:25 AM
cgeschwell
Feb 23, 2011 01:01 PM
